Using CSV Files To Your Advantage
Any data can be exported into a CSV file and uploaded to a cloud storage app like Box or Dropbox. That means that you can integrate almost any app on the market without an API connection or even a non-cloud app. While it may seem fairly obvious, it’s easy to forget what an asset these programs can be when automating an industry specific workflow.
The cloud app for enterprise service management, ServiceNow takes full advantage of this trick using Workato and Dropbox. This Workato integration (logic pictured above) brings in asset information (all servers, desktops, routers, etc.) from the CMDB (configuration management database) into ServiceNow, which allows tickets to be filed against those assets. This integration connects the SCCM (System Center Configuration Manager) with ServiceNow Express and was a key customer demand.
Case Study: Connecting with Industry Specific Applications
The Problem
FlightWorks, a Private Air Charter company, wanted to make their CRM, Salesforce, a more effective database by automating their workflow. To do this they needed to keep customer information in Salesforce along with the details of the flight that had been chartered. This proved challenging, as all flight logistics data were entered and stored in a legacy flight operations app that did not seamlessly integrate with Salesforce or provide the same benefits as the aviation Force.com app, Stack.Aero. In order to begin using Stack.Aero, FlightWorks needed their legacy program to integrate with Stack.Aero, which in turn natively integrates with Salesforce.
The Solution
Out of the box integration retailers tend to support more general apps, so without an expensive IT team to custom code an integration with this niche industry app, Flightworks couldn’t integrate. Stack.Aero decided to use Workato to create their own custom solution because there was no coding involved and it took only a few weeks to implement. Now Stack.Aero can integrate their own product with any app that their customers may need using Workato’s enterprise capabilities.How It Works
In order to get the flight logistics such as departure and arrival locations, data on their distance, fuel, etc. Flightworks uses the Workato recipe below, which utilizes Dropbox. Recipes are what Workato calls their integrations and are a set of tasks that get work done across your apps.
This recipe detects when a new file is added in Dropbox from the legacy flight operations app and automatically brings in the flight information from a CSV file into the Stack.Aero native Force.com app which then uses the Salesforce Force.com connector to put all the information into Salesforce, complete with support for custom objects and duplicate control. You can see in the recipe logic that Workato runs a very thorough search in each line of the CSV for the correct information, such as “If co-pilot name is present, then search for the account in Salesforce. If the account is not present, create a new one.”
A Step Further: Integrating with Intacct
A good automated workflow involves the seamless movement of data through all departments of your business and among the most important is the integration of your front end (CRM) and back end (accounting). Flightworks uses Intacct to handle accounting and this recipe brings all the necessary business data from the legacy flight app into Intacct using Dropbox.
Intacct is unique as an accounting system because it has “statistical accounts” for non-financial data that, together with the financial accounts, can create powerful digital dashboards. In order to take advantage of Intacct’s digital dashboard which visually displays important business insights, your information must be reformatted. This Workato recipe takes the reformatting step out of the equation and automatically populates these Intacct statistical accounts by parsing through the CSV for the correct information.
Workato can automate populating these statistical accounts from Salesforce, but with these CSV uploads via Dropbox, Workato can do this for almost any app – even if there’s no Workato connector or it’s not a cloud app.
